odu0485
- Sep 28, 2014
- 8
Are commonly published indeterminate beam formulas for continuous beams only for use with a constant cross-section? I assume so. When you have varying cross-sections as in many steel bridge plate girders with flange transitions, you can't just simply apply these common equations, correct? You'd have to use something like stiffness method or computer software to determine moments and shears, correct?
