FYI
In the 'Tubesheet Design Conditions' tab, I've been noticing in multiple models that the 'Yield Stress Source' and 'Modulus of Elasticity Source' drop down menus are cleared (blank)...that is no selection...after setting them and clicking 'OK' in the heat exchanger dialog.
If I remember correctly, these items are this way when entering a new vessel as well.
These items will continue to be cleared as described above each time the heat exchanger dialog is opened, but once the correct selection is made for your model, and the values read from the appropriate database, it appears that said values 'stick'. On the surface, it seems to be only a cosmetic problem.
Fitter, happier, more productive
