How to reduce cutting force of tool
Vxxxxx
91
I am performing 2D othorgonal cutting simulation of a certain material and I realised that the cutting force in the x-direction(reaction force on the tool) is two times larger than the results obtained from the experiment.
I tried reducing the friction coefficient but the cutting force reduced only by abit (5%). Right now, I am trying to reduce the value of damage evolution (shear damage) to see if it makes a bigger difference.
Is there any other effective ways to reduce the reaction force (RF1) of the tool in the simulation in order to get closer to experiment values? Thank you.
Can you attach pictures with contour plots of this reaction force (RF1) and stresses (on the deformed shape) ? How and where is the force measured in the experiment ?
At which point of the model have you measured this reaction force ? Can you show it in the picture ? And what is the title of this article ? I would take a look at it.
This reaction force is measured at the tip of my tool, and my tool is set as rigid body, so it doesnt matter where I set it. As for the article, I am sorry but this is a master thesis written in Chinese. The author actually did the same simulation and got a closer results than mine. (within 20% difference)
