I´m trying to simulate the contact between two gears. Each gear has 60 triangular teeth and all of them are in contact at the same time. I have one external gear and one internal gear. The internal gear is driven by a torque applied at it center. I know that I should fix the center of the gear but I don´t know how!, I mean which command should I use. I´ve been reading the manual and I couldn´t info about my problem.
I´ve started to use this program three weeks ago, so I´m new!
Best wishes.
Ezequiel
Best wishes.
Ezequiel
