Mar 14, 2003 Thread starter #3 P ProFishent Guest You must also change the Tolerance Mode under the properties of each dimension. Otherwise their will be no tolerance to be seen!
Mar 14, 2003 Thread starter #4 L leventy Guest option>save something.pro>change tol_mode i.g. limits or nominal byes
