I have a customer questioning the distance between 2 butt welds on a piping system (photo available) designed (customer spec'd) to B31.1. While they cannot cite a code that prohibits it, they state: "The two closely-spaced weldings is NOT a good practice. Generally there should be enough gap (space) so that Heat Treated Regions do not overlap each other." and are referring to ASME Boiler & Pressure vessel code , vol. VIII Part UW REQUIREMENTS FOR PRESSURE VESSELS FABRICATED BY WELDING Serie UW-9 , Design of welded joints , paragraph (d).
Question is:
• What, if any, is the relevance to the ASME boiler code VIII section listed above to ASME B31.1?
o If a pipe was constructed to B31.1, does the boiler code VIII apply in any way to this situation?
• What rules or part of either code relate to the proximity (HAZ – Heat Affected Zones) of the butt welds in question?
o How close by code can two welds be made to each other?
• What relevance does NDT have to assuring that the proximity of the welds is satisfactory?
o Can NDT provide assurance that a design meets code?
Question is:
