High Pressure Adapter to Grip Multiple .012" Tubes
dreinsdo
I am looking for an adapter that can handle pressures up to 650psi. I've been looking into touhy-borst adapters, have done a fair bit of searching, and been unsuccessful thus far in finding one that does so. Anyone know where I can find one?
My goal is to grip multiple .012" tubes and send 600psi fluid through them, without leaking. A small amount of leakage, although not desired. is permissible.
How many tube?
What are your size constraints?
What is the tube material?
Is this a short or long term setup?
(1) The number of tubes can range, anywhere from 1 to 10
(2) No size constraints on the size of the adapter (I'm assuming you were referring to the gripper/adapter itself)
(3) The tube material is stainless 304
(4) Long term setup
