Drilling Integrity Super.
While working on an inspection procedure for process piping in drilling units, I noticed an interesting detail in the ASME B31.3 code. This standard separates low-pressure and high-pressure systems into different chapters.
A key point in this process is the calculation of minimum required thickness, which depends on the minimum allowable stress of the material. These values are listed in the code:
Have you come across this in your work? Share your thoughts in the comments!
- Table A-1: For low-pressure systems.
- Table K-1: For high-pressure systems.
