Does anyone know of a pump that can be sized to handle Glycol (TEG) @ 11-1200 psi, 1 GPM & 250-350 degrees F? I have called numerious salesmen and no one knows of anything to fit this application. Any help would be greatly appreciated!
You are in the upper temperature range for ethylene glycol. Are you not concerned about coking? One of the synthtic heat transfer fluids maybe more appropriate.
