ColinPearson
Petroleum
Hi all:
Looking for a bit of advice on how to apply some of the Roark tables (or possibly a case from Moody that is not included in Roark, but I do not have access to Moody). I have an additional question regarding LTB that is included in the same design situation. I have uploaded a pdf of the structural steel that makes up the floor under the valve - where I have to roll it across).
I need to find a cart or use some Hilman rollers to remove a valve from a process unit. For discussion, let's call this valve 10kips (rounded up by a couple hundred pounds). This valve needs to be moved across what I would call a continuous sheet of 1/4" diamond plate to where it can be lowered for repair. The diamond plate is sitting on beams at 2'-8" centers and each sheet is welded to the next. I do not see which Roark table directly applies...
- The continuous plate tables do not include very many support conditions
- I don't believe I can reasonably consider all edges fixed.
- Even though the plates are welded together (and welded to each supporting beam), I do not want to guess anything about the quality of the welds, so I believe I could reasonably consider the long edges (along the supporting beams) simply supported, but that leaves me wondering what to do with the short edges (perpendicular to the beams) - surely the continuous plate makes those short edges better than free?
- How would the industry consider the side lengths a and b with a continuous plate like this?
I know that plate itself is no good for the whole weight (despite what our boilermakers say), but I want to find out how much it is good for so I can accurately gauge what additional reinforcement needs to be installed. So, two questions with this plate:
(1) Can someone offer advice on which (if any) Roark case applies to the existing diamond plate?
(2) If I lay plate on top of this existing diamond plate, is it fair to consider all edges of the additional plate as simply supported? (Even though two edges will be over beam and the other two will be supported by the existing plate only).
One final question regarding the existing beams under the diamond plate...
(3) Can anyone offer their advice on what to consider for the unbraced length given that the plate is continuously welded along the top side (middle of flange) along the entire length of the beams?
Thanks all, cheers.
Colin Pearson
Thanks all, cheers.
Colin Pearson
