atrizzy
- Mar 30, 2017
- 365
I'm trying to use Staad.pro to calculate the frequency of a foundation I'm designing, and am using ACI 351.3 as a guide for calculating equivalent springs at the base of the footing.
Calculating the impedance at the base for the various conditions is fairly straightforward, but I have a few questions for those with more experience here:
Any other advice would be great, and thanks in advance!
- Do we need a separate model for all DOF considered (rocking, vertical, torsion, etc)? Seems like, for instance, the rocking and vertical impedance may yield contradictory values for the base support spring constants. But of course the purpose of the modal calculation is to assess all of the system's potential dynamic modes... Help!
- Presumably the base springs should be compression only, correct?
- Is it common to neglect the effect of burial (side contact between the foundation and backfill/embedment material) for this sort of model? Presumably it's conservative to do so...
