Happyfeet63
I am an ME, now disabled, working from home (95% for my 35 yr. career was spent in mfg. mgmt. – so I am very rusty) and am designing a drilling center for drilling a hole in ea. side of a Hex coupling nut (simultaneously). Need a bit setup gauge for bit changes in the drill heads utilizing the pic & place system. It has 2 sizes of Hex on the same short shaft. Need to Tolerance this for making the sides of the 2 Hex sizes within certain degrees of each other around the center axis. Do not know quite what nomenclature to use in the FCF.
Any suggestions would be appreciated!
Thanks,
Larry
Thanks,
Larry
