Hello, I need some advice please,
(I am using Inventor 2008 pro Vista)
I have produced an 'Air Nozzle Hub' with 12 vanes (rotated) equally spaced between two rolled ring diameters, the vanes are at an angle. I made the vane in a part file, then saved it to a assembly file, I then positioned the vane and cut it at the required diameters, to produce suitable profiles for it to fit within the hub, (i'e' two rolled ring dimeters)
I can't seem to dimension this vane in the IDW file, I have tried the intersection tool but no matter what I do I cannot cannot get enough dimensional info for detail,
1) Is there any way I can make a flat template from this assembly?.
2) Have I modeled a vane that is perfect for the job, but not suitable for Inventor to dimension?
any advice would be appreciated
amsmarle
amsmarle
