I have a client who, as part of a bridge repair project, would like to have the aluminum railings cleaned and/or coated.
The railings are constructed of uncoated aluminum, either 6061-T6 or 6351-T5. They are approximately 50 years old. The client would like to remove the heavy layer of oxidation from the surface.
If I were to specify that the railing be cleaned by say, soda or bead blasting, it's my understanding that the aluminum would immediately begin to oxidize again. How long would it be before the oxidation became visible and begin to dull the sheen of the railing? If it were, say, more than a year, the client may be satisfied with just cleaning it and calling it a day. If much quicker, could a clear coating, such as a urethane or similar product, be applied to prevent the immediate re-oxidation.
I'm concerned about using a coating such as a urethane for a number of reasons: Would it be difficult to field apply at the correct thickness? Would it prone to peeling? After a few years (assuming the coating lifespan of 3-5 years) would the aluminum begin to oxidize normally, or would the client need be committed to continue re-applying the coating?
Note: The railing cannot be removed from the bridge to be shop cleaned/coated.
Thanks.
Thanks.
