extremechanical
Hi, I have a pump which is beneath a tank. It's actual motor is .63 hp, 1200 rpm
Maintenance wants to couple it with 1.5 hp motor with 1800 rpm
I want to know what is effect when a pump is coupled to higher rpm and higher hp motor than vendor designed values
Will it increase velocity at suction and then what is the effect on npsh. What if the pump is not flooded .
Please explain if suction speed or npsh changes also come into effect .
