TOOLS4FOOLS
Aerospace
I'm pretty consistent on drawing layouts (i.e. format: Note callout, Hole callout, Dimensioning to the best
features and between views). One thing I never got a handle on was using TYP, 3 Places, as oppose to 2X or 4X.
Lets say a square part has a dim. that is 2.00 long. I use 2X, 2.00 As oppose to placing two dimensions on the drawing view. I have seen some prints regarding the same intent but Specifies 2.00, TYP. And what about 2 places? If I had a hole callout that said this Thru hole is .20, 2 places. I would use 2X. Are there different discipline between using 2 Places, and Typ with regards to using 2X? Or is this a Drafters preference
Also how does one get his feet wet to become a Tool and Die Designer. Is that something you fall into or
something you have to pick up on your own? How do you get your tool and die design break? What would one do
instead of waiting around to be one?
