abusementpark
It is pretty common to have a diaphragm (metal deck or concrete over metal deck) supported by steel joists over structural steel framing. For the case of steel joists spanning perpendicular to collector beams along a frame line, how do you normally assume the lateral load gets from the diaphragm to the steel collector beam, since there is a 2.5" gap (joist seat depth) thru which the lateral force needs to be transferred?
