Yes, it doesn't matter as long as the part is saturated. Since you are only doing a fast & simple experiment, it'll be difficult to tell if you saturated the part. You'd need some method to measure the complete hysteresis loop to tell how far beyond the "knee" you are.
The only option I can think of is to magnetize the part, measure the magnetic output, then increase the magnetizing pulse by 10% (or some other, arbitrary value) to see if you get a higher reading. Keep increasing the magnetizing pulse until you see minimal to no increases in magnetic output on the steel. At that point, you can be reasonably sure the part was saturated.
