CoryPad,
you are correct re 'moot.' I intended something like, "all further discussion is moot until we have more info from gvh," but suddenly found I was late for an appointment.
I also admit to thinking of gvh's case as if he were a customer who walked in the door with a part. I would have his answer in ~no time and for no charge.
gvh, since CoreyPad raised the issue, how did you remove the paint?
I'll risk sticking my neck out again and suggest that sandblasting, as commonly practised, is not recommended for removing paint from aluminum unless you know ab initio that a layer of anodize exists. We sometimes use glass bead.
Further, it would be highly unusual for a very thin anodize layer (what we in the business call "flash anodize"
to be present beneath paint since that is normally used for appearance sake, to give some protection on bright polished parts. When we have a call-out for paint over anodize, it normally is a significant thickness (Type II or III) for added protection from corrosion and deep scratches. A conversion coating is much more commonly used pre-painting. Again, this is a only a probability based upon years of experience, but we could be dealing with the exceptional case.
For aluminum parts that are free of paint, another referee method for anodize thickness (weight) is ASTM B137, which I like since I have the acids and analytical balance required, but I considered it impractical, so again I could be wrong if gvh has a lab.
nbucska, your method has been used for studying the oxide film that develops naturally on cleaned aluminum as a function of time [for this, as CorePad pointed out, a sharp probe would be unsuitable]. A thin layer forms ~instantly in air; then slowly, at a parabollically decaying rate, reaches about 300 Angstroms (?) after 30 days. Perhaps TEV has studied this by high-tech means and could explain better.
