Fatstress: Failure modes in our specimens were not unusual in the vast majority of cases. Cracks initiated at the hole periphery, perpendicular, or almost perpendicular, to the applied load direction. Failure sections were subjected to a quick fractographic inspection to confirm that the failure was typical. We had good results in both 2xxx and 7xxx alloys. Perhaps there is something about the material thicknesses used, or differences in fastener installation standards, etc, the lead to different results, or maybe it was to do with loading. So many variables…
wktaylor: We used to categorise joints as either HLTJ or LLTJ. We didn't talk about MLTJs. Our HLTJ fatigue coupons were arranged so that all the load in the joint was transferred by two equally-loaded bolts, so I guess that our definition of a HLTJ was one in which 50% or more of the load was being transferred through a single fastener.
Our LLTJ specimens also contained two equally-loaded fasteners, but not all of the load in the joint was transferred through the bolts, so the total bolt load was less than the load in the joint, and thus the load transfer per bolt was less than 50% of the load in the joint. Regrettably, I do not have ready access to the percentage load transfer that this configuration gave us. Maybe other organizations would have classified these as MLTJs.
For conservatism, we used to analyse skin-spar joints using HLTJ data, even though the load transfer per fastener was less than 50% of the joint load. Skin-stringer attachments were usually analysed using LLTJ data. Fittings were usually treated as HLTJs.
Maybe the ratio of bearing stress to net stress is a better way to charaterise what is happening in the material, rather than percentages of load transferred.
As far as Cx processes go, we usually used 4% Cx, less for large holes, and always performed a final ream operation. There was some minor discussion about Cx to final size, but that had not resulted in any conclusions by the time that my fatigue work ended at that organisation. Additionally, although we were aware of the ForceMate system, we did not take into account any fatigue benefit in the calculations because we had no auditable data for it. We used it only in selected locations, and not for fatigue reasons.
The comments about temperature cycle effects are interesting, although I regret that I can not add anything meaningful to that discussion. All our testing was performed in ambient lab environments, and the subsequent, statistically-processed results were used directly in our analyses. I am not aware of any artificial aging of the material prior to testing, although perhaps there was some; I just don't know. Furthermore, we had temperature probes on the coupons to ensure that they did not get too warm during the rapid constant amplitude load cycling.
Another interesting temperature question concerns the effect on fracture toughness. It is common knowledge that reduced temperature tends to result in reduced fracture toughness. If you have a limit load case that occurs at cruise altitude (I'm thinking commercial transports here) when the structure will be cold, how can you ensure that a crack of a given size will not be critical when the you have only room-temperature fracture toughness data to work with? One answer that was suggested to me was that the issue was not a great concern because, in practice, actual, real-life limit load encounters tended to occur at low altitudes!
