Coulomb's passive pressure equation may be flawed
yahoo123
Bioengineer
When I use the following values, the Kp coefficient a whopping 46!!!
pheta = 5
beta = 20
phi = 30
delta = 15
When using some other combinations, the Kp value can reach in excess of 100! Is the Coulomb's passive pressure equation flawed?
Roughly the first case you describe, the kp value should be about 6 to 6.5 (see Bowles, see Fang). Fang, for logrithmic surface, for phi = 30, the kp value ranges from 3 to slightly above 6. Did you happen to use excel where the angles have to be put in as radians instead of degrees?
How did you get 6 to 6.5? I did it in both excel and confirmed it by hand a few times and the same answer. I converted the degrees to radians when I did it in excel.
I also tried the Coulomb's equation in a different written differently (Civil Engineering Reference Manual 10th Edition by Lindeberg) and I still got the same answer.
First off, the equation given in the wikipedia is not the normal one that I have seen for Coulomb. See Bowles 6th edition, equation 11-6 (page 596)for example. I normally wouldn't "calculate" the value - I'd go to a table. For the value of 6 to 6.5, I went to Fang, Figure 6.9 at 30 deg to get a typical value of 6 for level backfill (log-spiral). As the wikipedia doesn't well define the terms (a sketch showing the terms would help) I used phi30, delta 16, Slope behind increasing at 5deg - you get 6.6. So 6 to 6.5 seems to be in the right ballpark. Do a check on other sources for the formula as well - most use a sin^2(alpha - phi). In Bowles table, the minimum value of kp is 1.914 (phi = 26deg, delta = 0, slope behind wall decreasing at 10deg, vertical wall) to an extreme of 87 (phi = 42deg, delta = 22deg; vertical wall and slope increasing at 15deg.
More proof Wikipedia is a failed experiment??
Typically the angle of the back of the wall is measured from horiz. not vert. As Big H said, the equations don't look familiar. (there are a couple variations of the equations out there, but they all look fairly similiar and yield similar results) For the numbers you gave with a positive 20 deg backfill, 85 deg backslope to the wall, phi =30 and wall frition = 15deg, I got Kp = 11.4, using log sprial charts I got Kp = 11.9
Bottom line is you get what you pay for and wikipdia is worth its price.
I used the equation out of Pile Buck's Steel Sheet Piling Design Manual. I used Phi = 30 degrees; wall friction = 15 degrees; slope behind wall = 20 degrees; slope below wall = 5 degrees. Kp = 6.310
I also used the Civil Engineering Reference Manual, which is written differently than the one on Wikipedia, but got the same result of 46.
Very strange.
When I gave my previous answer, I assumed that the slope in front of the wall was an upward +5 degree slope. The original post just said 5 degrees. If the slope is a downward slope (-5 degrees), my Kp reduces to 3.961.
In Bowles' 1968 book, his table give Kp = 4.976 for phi = 30, beta = +20, delta = 15, a flat ground surface in front of the wall base, and a vertical wall. Therefore, if the ground slopes downward at 5 degrees, his Kp should be less than 4.976. Bowles' table does not list Kp for the downward slope.
