Concrete filled brick retaining - wall max height
demayeng
AU
I've been told there is a maximum height of 1100mm (3ft something) on brick retaining walls (2 brick skins with a 100mm concrete filled cavity).
I think it has to do with deflection, however I'm not sure.
Does anyone else know why this is and if it's true?
I guess there is an issue with the wet concrete applying too much pressure over a certain height, although I imagine you could solve that with a slow pour rate or multiple pours.
I assume also with this type of wall that because you don't have the 'clean-out blocks' of concrete block walls, so you may get dodgy corefill at the bottom... Maybe that is why the height is limited..
Any thoughts..?
hey just came across this post and realised i have a questions about this topic.
would a double skinned brick retaining wall be able to support as high as 3m. and also what would be a recommended cavity width?
