We manufacture pressure vessels and execute 3 integrity/release tests ahead of shipping the units.
1. Hydrostatic Testing 1,43 x design pressure (30 min)
2. Vaccum Test (Pull Down to full vacuum)
3. Helium Leak Testing (8 Bars Helium)
At commisioning the customer executes a leak test using either air or nitrogen, as media for testing. (Pneumatic Testing)
Pneumatic testing should be done at a lower pressure level, given the viscosity and surface tension of air is much lower for air/N2 than water, to simulate the same leak detection level as for the factory hydrostatic test already executed.
At what level of pressure should one accept this pneumatic leak test to take place, considering the factory hydrostatic test has been executed at 1,43 x design pressure ?
Best Regards Ole
Best Regards Ole
