If i have 2 seperate pipes combining at one common point in the system what will happen to the flow and pressure at that point
i have one pump on one line pumping at say 2l/s@ 2 bar and another pump in the second line pumping at 4l/s @ 1 bar, when the combine at the common point what will the resultant flow and pressure be?
Will one pump stop the other from pumping?
