Collin_St203
- Jan 25, 2022
- 9
I am designing this retention using capping beams on piers. Capping beams are arranged to suit the slope and because of this I have to build walls (which are up to 1.7m high) above capping beams and then connect to the ground floor slab on top as shown below.
I am not sure if this is acceptable.
My concern is that the capping beam is not at where the floor diaphragm is so I am using the torsion capacity of the capping beam to avoid the 'pin' wall-capping connection. Any comments?
