Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
My interpretation is slightly different rather than saying "connection can be used to transfer moment" I read "connection develops/resists moment"KootK said:Right, but I would interpret those things to mean that such connections can be used to transfer moment when desired.
DaveAtkins said:I stand corrected. There is a small moment transferred to the column (1.8 kip-ft). You can see that in the moment diagram above, but it is easy to miss because it does not show up graphically. If I load the middle bay with only dead load, the moment on the column becomes 3.5 kip-ft.
Gave advice and made a statement that is plainly false. (sure you can ignore moments if you wish, but you can't just assume them away!) And everybody knows the best way to arrive at vigorous discussion on the internet is to lead with a plainly false answer to a question.271828 said:I'm wondering what DaveAtkins has done to human909. LOL
As I've said repeatedly in this thread and others in most cases you hypothesis is mostly correct regarding strength. However is it readily proven untrue in a variety of other circumstances, including serviceability and in strength. Examples of this little this thread and threads previous.Eng16080 said:Hypothesis: A structure designed with pinned connections versus fixed or partially fixed will result in a conservative design.
I see above that human909 has an example initially claiming to meet this condition, but the comment was later edited to the contrary.
You still don't get it. I don't have a problem if you design a structure with this connection as pinned. I do have a problem with your initial reply the the question.DaveAtkins said:You are entitled to your opinion, and your method of analyzing this type of structure. As can be seen throughout this thread (in the comments by many structural engineers), as well as in the recommendations from Steel Tube Institute, my way of designing this type of connection is also accepted engineering practice.
That should have been a massive red flag for you. If the columns are deflecting with curvature they must have moment.DaveAtkins said:Even though the columns deflect, they do not receive any moment. The moment in the cantilever equals the moment in the backspan. So maybe we are arguing over nothing?
A good question.phamENG said:I'm more curious about the curvature. To me, the 'make everything thin' argument depends on the ability of those thin parts to deform elastically to allow that rotation to take place without the top of the column rotating appreciably. So if we know the curvature of the beam at that point, we can determine if it's realistic for the plate to deform that much.
human909 said:I do have a problem with your initial reply the the question.
DaveAtkins said:So if moment to the column is considered it definitely increases the unity check.
SE2607 said:Soooo...assuming pinned connection is unconservative.
phamENG said:Jeb - I disagree. I think the 14% is accurate
