Canned Motor Pump
a1987
IT
Dear Sirs,
i have received a process data sheet for a canned motor pump..
in this document should i find the indication of containment/control system and the indication of cooling system for bearings??
i think yes, but i'm very doubtful...
thanks
I assume you mean a can pump. Look one up on google and then you'll have some idea what one is. Containment /control ??. Cooling system for can pumps is normally the process fluid.
My motto: Learn something new every day
Also: There's usually a good reason why everyone does it that way
Don't see many canned motor pumps these days, but they still are out there. Some will have circulating loop for a lubricating fluid, some won't, it depends on what you're doing with it.
My fault. Never heard of canned motor before. Delete previous post.
A "process" data sheet usually only contains hydraulic data required by the process. Mechanical design details should come from the manufacturer or from set of end-users specifications for a canned motor pump.
DOn't see many at all these days is right; mostly replaced by sealless/ mag drive pumps. I was told it is too hard to get that marriage between a pump and motor manufacturer required to update the old designs.
