Don,
Two seconds may cover the conversion from millimeters to inches, but not everything is so simple. A vehicle crash simulation requires a self-consistent set of units to perform accurately - you can't just convert pounds and inches as you see fit. You can back calculate the kilogram to slug relationship, but only by knowing the Earth's gravitational constant (which is measured and reported in SI).
Try a corrosion or electroplating equation that requires Avogadro's number. There isn't a slug-friendly version of that lying around.
SI wasn't dreamed up as a way to pit the USA against the rest of the world. As a matter of fact, Americans at NIST are among the most influential in furthering SI for the betterment of society.
Based on your reported age, I would say that we are contemporaries rather than separated by a significant age difference.
Cory
