kafman
- Feb 16, 2025
- 7
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
If you click on one of the images there will be a zoomed out overlay image with selection arrows.Can you add a zoomed out picture?
first thanks for ur consideration, the fan was normal,but on going the fan's blades(just one side) got wornout due to the clinker abrasive material since it is fan for bag filter around clinker transportation,,the image shows only 2 blades out of 12,it is such oblique view, but all the blades have similar wornout surfaceNothing here makes sense to me.
Three identical pictures of what seems to be an impellor, but it has a solid inner core? EDIT - I now see once I click on the photo that we're actually looking at two blades of the impellor... difficult to see the trailing edge of the top one.
Also doesn't look circular but maybe that the optics.
hat has caused this t crack? If you don't solve the cause then you will be back at the same place pretty soon.
More pictures or a sectional drawing needed here.
EDIT: And what "EXACTLY" is the damage? just that little nick in the top blade or something else. Is that a weld gap or just some black gunge?
