Geez! How much lateral movement do you have? The tolerance under gravity loads only is typically "ZERO"! Is there differential settlement? How long has this been going on? Have you set up any form of monitoring? Is there any evidence of distress? If there is differential settlement, the frame of the building might be undergoing more displacement than designed.....>>>>higher stresses. What type of building frame is it?
