Bug Zapper Ceramic Disc Capacitor Replacement
Bullrunner99
Industrial
Aug 8, 2023
I am a novice with no electronic experience. This is a vintage SEARS BUGWACKER, MODEL 833.1432, INPUT 120V AC 60HZ 45 WATT, WITH A GRID MAX OF 5000V. The specs indicate 9 MA which I believe is milliamps. These insect zappers I believe were later known as Flowtron brand.
The two electrical grids are no longer electrified. Under the hood of the insect zapper are two ceramic capacitors. I assume them to be 5000 volts matching the product specs. I do not know the picofarad rating of the OEM capacitors? A repair handyman has determined that one capacitor failed.
I purchased Ceramic Disc Capacitors 100pf 0.1nf 101 10000V. The repair technician kept the one working OEM capacitor (5000V assumed) connected, and put two 10000V capacitors one the other side replacing the failed one. This seems imbalanced to me, since the two electrical grids on the zapper are still not electrified. The unit now has three capacitors, one OEM at 5000v and two 10000v.
Questions please:
  • Is it acceptable to replace the two OEM capacitors with ones having voltages above 5000, such as 7000 or 10,000 volts? Sourcing 5000v capacitors has been a challenge. Does this effectively increase the voltage capability of the elecrical grids?
  • How many picofarads is required on a replacement capacitor? Is a lower number better? Is 100pf acceptable, as purchased?
  • Do the two replacement capacitors need to be of the same voltage?
  • Might this be a Ballast or Transformer issue also?
  • Any sourcing help for these components would be appreciated.
I have replacement Starters available. The OEM Starter is FLOWTRON FS-25X 25W.
I do not have a manual for the exact model. Attached is one for a similar, but different model.
Thank you much.
  • Sears Bugwacker Manual Model 833.14344.pdf
It is perfectly acceptable to replace a 5000V capacitor with a 10,000V capacitor.
One trick here is IF the value needed is 100pF, you could take two, 200pF capacitors of 2500V and connect them in series. This gives the equivalent of 100pF at 5000V. This works if the capacitors are identical in value/voltage.
The question is, what was the value of the original OEM capacitor.
The two "Ballast" transformers shown in the manual are likely for the florescent bulb light, and not part of the zapper. The FS-25X is a florescent bulb starter, same as you might find in a florescent desk lamp of 25 watts.
Item 12 in the manual appears to show the High-voltage step-up transformer. This appears to be a laminated silicon steel type (low frequency) which leads me to believe the design directly steps-up the incoming 60Hz AC rather than using a flyback-type transformer similar to what would be found in a CRT TV (a higher frequency in the kHz). What I'm getting at is 100pF may not be enough at a low frequency.
To get more pf connection to the grid, you can parallel the capacitors. Two 100pf 10,000V capacitors hooked in parallel give 200pF 10,000V worth of capacitance. It would help to get the capacitance of the OEM capacitor measured, then you would know what you needed.
