Boeing 737 Max8 Aircraft Crashes and Investigations [Part 8] 24
Sparweb
Aerospace
CA
This post is the continuation from this series of previous threads:
thread815-445840
thread815-450258
thread815-452000
thread815-454283
thread815-457125
thread815-461989
thread815-466401
This topic is broken into multiple threads due to the length to be scrolled, and images to load, creating long load times for some users and devices.
If you are NEW to this discussion, please read the above threads prior to posting, to avoid rehashing old discussions.
Thank you everyone for your interest! I have learned a lot from the discussion, too.
Some key references:
Ethiopian CAA preliminary report (Link from Ethiopia is now broken. See link from NTSB Investigations below)
Indonesian National Transportation Safety Committee preliminary report
NTSB Investigations
NTSB Safety Recommendation Report: Assumptions Used in the Safety Assessment Process and the
Effects of Multiple Alerts and Indications on Pilot Performance
A Boeing 737 Technical Site
Washington Post: When Will Boeing 737 Max Fly Again and More Questions
BBC: Boeing to temporarily halt 737 Max production in January
Pulitzer Prize, For groundbreaking stories that exposed design flaws in the Boeing 737 MAX that led to two deadly crashes and revealed failures in government oversight.
I vaguely recall from my first year economics class that monopolies are bad, and duopolies are only less bad. Here we have a de facto duopoly.
Maybe transport aircraft manufacturing needs to become a regulated public utility.
or maybe just properly regulated...
Isthat a typo?
Did you mean "just poorly regulated?"
No problem with poor regulation.
The agency is already in place.
The FAA.
Bill
Ohm's law
Not just a good idea;
It's the LAW!
then maybe they should do their job then...
I banned 737s from my personal space. Not important to me if govs do, or don't agree with my policy.
There may also be a link to the 737-500 Indonesian crash with the auto throttle issue.
They have had issues with the AT since the 737-200. But mainly its the crew alerting system which is the issue. The fact it doesn't and the save is that the pilots have to recognise the issue and disconnect it from memory inside the magical boeing reaction time assumption.
FAA just approved the 737 MAX 8200 variant.
This is for Ryanair think its a max 8 but with 200 seats.
Seems double figures worth of them are grounded again due to them having an electrical issue with grounding.
Bugger!
Bugger
(The devil made me do it.)
Bill
Ohm's law
It's the LAW!
If your interested someone changed the method of securing power control units to racks from rivets to fast fasteners on the production line. These fasteners don't give a grounding bond to the airframe.
Don't have a clue what the implications of that are with the electrical system, I am sure Lou and Bill does though.
Well if the electrical system is built with the same principle as a car, which it seems to bee looking at this picture.
Where all minuses goes via the ground and not via separate cables back to the power source.
Then the problem becomes the same as having a a bad minus pole or earthing in a car.
Anything can happen and things just stopp working.
What this "fast fasteners" are I am not shore, the word can probably be used for a lot of different rivets, screws etc.
Best Regards A
Albert Einstein
They are push and turn to lock type clip there is a T on the end of the shaft which goes through a hole with a slot. You then push against a spring and turn and the T then has metal under it and holds them in.
Well that's what they usually are for cowls and fairings. Avionics Usually has threaded lock bars which get tightened to keep the connections good in the rack then wire locked so they can't move.
I think the anything can happen is the reason why they have stopped them flying before the FAA has had time to produce the official paper work requiring it.
To note this is the power distribution not the flight control system although as you say it may screw up everything.
Okey I know what you mean, we have those kind of fasteners on some electrical cabinet doors.
There was talk about a fire hazard.
So my guess is that if the unit isn't tightened enough, there can be discharges and light arcs, causing fire.
/A
Albert Einstein
No clue. I presume that they are not certified for electrical purposes and changing them by production line kangaroo court has certification and QA issues.
The actual issue itself is one thing, the corporate mentality that anyone on the construction hanger production line can anyway consider it acceptable to change anything without it going through a QA checking process is completely another. If the QA process has signed it off acceptable then that another colossal issue.
Bill, [rofl][thumbsup]
Boeing may still have culture issues.
Again;
"If it's Boeing, I'm not going."
Bill
Ohm's law
It's the LAW!
