GeezerGeek
After searching the net for help designing recumbent bicycle fairings, I found good technical information about fully faired bikes used to break land speed records but there was very little technical information about partial fairings (windscreens). It seems that most people who post have designed their partial fairings by trial and error and test them by timing themselves on long rides – very imprecise.
A good partial fairing should have a low Cd from the front, minimal side area, be light weight, and get lift from side winds. Some of these are conflicting requirements so I want to make a design decision after testing wind loads from different angles. My goal is to develop an easy and inexpensive tool that bicycling hobbyists can use to test different designs. To do so, I built a wind tunnel out of cardboard boxes and a window fan.
The Reynolds number for the bike should be in the 300K range and my models with this wind tunnel have a Reynolds number of about 50K. Spherical designs will have poor correlation because of the different Reynolds numbers but I am hoping for the best with a shape similar to a thin slice off the side of a cylinder.
To test the wind tunnel, I have tested different sized disks. They should have a Cd of 1.17 but I am getting numbers from 1.1 to 2.0 depending on size. The larger the disk the larger the tested Cd. The test section of the wind tunnel is 12 inches X 15 inches ( 30.5 cm X by 38 cm) and the largest disk has an area 10% that of the wind tunnel or 5 inches (12.7 cm).
Are the errors in Cd because of boundary layer effects?
If so, how far from a wall does the disk have to be or conversely, how big does the wind tunnel have to be to reduce boundary layer errors to less than 20%?
Does anybody know of any good info on the web for designing bicycle wind screens for reumbents besides those designed by trial and error on full scale models?
