Assembly rotate by repositioning and keep constraints
Ehaviv
Computer
Jul 2, 2003
1,012
Hi
Using nx11
I want to reposition rotate an assembly
and keep constraints applied.
The assembly us not mine and so
I don't know which pZrt is the base
For all constraints and also maybe
Some components are free without constraints.
Currently I do that with many steps
of repositioning.
Thank you.
Code:
Using nx11
The assembly is not mine and so
I don't know which part is the base
of repositioning.
Please can someone help to make
It a reasonable work.
THANK YOU.
To determine which part is the "base", possibly check if any of them are constrained with FIXED, because probably that is the one. Then remove that FIXED constraint to rotate it.
Jerry J.
UGV5-NX11
Jerry thank you.
That was my first check.
There is no fixed constraint.
