KLineDesign
Bioengineer
Hello All, I did a bit of searching and am looking of the best way to sweep a mechanism between limits. In the past, using mating conditions, I'd often 'vary constraints' to show the sweep of something. (Is this still available in NX7.5?..couldn't find it.) Now, I usually just know the angle of the stops, and vary an expression between the angles ends (several key-ins). Or sometimes I use multiple constraints suppressing those that are not needed to show the positions. However, I want to vary an angle by sweeping (much like in vary constraints) between it's mechanical limits using the dynamic handles, or by having arrangements cycle through a range. What is the best way to accomplish this?
Regards, and have a Great Weekend!
KLINE
KLINE
