API plan 62 - steam Quench with orifice 1
nirlt
14
Please advice whether Seal plan 62 (steam quench) scheme can have Restriction Orifice for reduction of available steam header pressure to required pressure for quench.
Yes, it can but I would still use a needle valve or similar upstream of the orifice. Depends on what orifice diameter you will use and header pressure also.
normally orifice size for API plan62 Steam Quench is 1/16" (1.5mm) and API Plan11 is 1/8" (3.5mm)
Yes, orofice can be used. No. of orifice will depend on desired pressure drop. Normally 3 to 5 psi pressure for plan 62 is good enough.
Instead of orifice a needle valve with small opening will be better choice.
