APDL: SHELL181 stress decomposition- SMISC 34 to 47
SuG89
IN
Hello everyone,
For SHELL181 element, SMISC quantities from number 34 to 47 are;
Sm: 11, 22, 12 Membrane stresses
Sb: 11, 22, 12 Bending stresses
Sp: 11, 22, 12 Peak stresses
St: 13, 23 Averaged transverse shear stresses
There is an option of stress linearization in Path operations which returns membrane, membrane+bending and total stresses. Are the above listed SMISC quantities doing the same thing as the stress linearization option under 'Path operations'?
Where can I find more information on how these quantities are being calculated by Ansys? I searched the manual but could not find information about the background theory for these SMISC quantities.
The purpose of my analysis is to study whether the dome structure is in a very good membrane state (negligible bending) or significant bending state. I think this can be done using Sm and Sb.
_________________
Best regards,
Sushant Goel
MSc Uni Stuttgart
Make a simple model and compare it to hand calculations.
Rick Fischer
Principal Engineer
Argonne National Laboratory
Ok Mr Fischer. Thank you.
Best regards,
Sushant Goel
MSc Uni Stuttgart
Yeah, but did you do it? Or did you pester the folks over at xansys?
Rick Fischer
Principal Engineer
Dear Mr Fischer,
I found the relevant formulas in section '2.3.3. Shell Element Output'. Also, I made a small plate model in APDL with the longitudinal direction of plate aligned to x-axes. From contour plot> element solution> stress > sx, I got the top (-0.292) and bottom (0.142) surfaces total stress.
Then, I used the element table options to get N11 stress (-0.074) and SB11 stress (-0.217).
-0.074 + (-0.217) = -0.291
-0.074 - (-0.217) = +0.143
Best,
Sushant Goel
MSc Uni Stuttgart
