Application is for use on Test Caps and Plugs used to pressure test assemblies with premium self sealing buttress type threads without damaging either the assembly or test equipment. This would be to prevent galling. The threads on these assemblies are casing threads and are made to be made-up several times at most. We get away with more now because we use lower torques or low-torque thread form test cap options. The threads are peened for galling resistance and the box threads are phosphated. That is OK for the assembly but the test cap and plug will eventually wear out then problems occur.
I like what have read about TDC and XADC (78 and 98 RC respectively). I do worry about cracking in the thread root radius. I was wondering if this would be a good alternative. Material is 110 ksi MYS 41XX LAS with 36 Rc. Perhaps case hardening is option.
- CJ
- CJ
