I am a young mechanical at a aluminum fab shop. We weld most of our connections and I have been having a serious problem with weld contamination from of punch fliud. I realize the importance of cleanliness for aluminum welding but it is essential that I use some type of cutting fluid mixture for our turret punch. Currently we use a mixture of cutting fluid, transmission fluid and water on our punch and then attempt to wipe them down before welding. Needless to say the surface remains somewhat oily. I am looking for suggestions on a different fluid that will not effect the welds or any quick technique we could use to clean the weld areas. Thank you in advance for your time.
DiBlazing
DiBlazing
