Air to Boil Temperature
KB001
I am trying to find the Air to Boil Temperature for my Radiator ( Air cooled heat exchanger). Given the LAT, Max top tank tempeature & boiling point of 50-50 Ethylene Glycol, is there any way to find air to boil ? If there's any alternate way based on Heat Transfer capacity etc, can you let me know.
Each time I find different methods from different sources and not quite sure which one is correct.
Thanks,
KB001
Let me get this straight. Are you saying you want to boil 50/50 % ethylene glycol in an air cooler?
Are you asking for how hot the ambient air can be before the coolant boils?
TTFN
FAQ731-376
If so, then you're probably better off just measuring the temperature rise and subtracting that from your max temp
TTFN
FAQ731-376
