I disagree and Henry's law can be used, as long as the concentration remains low. It's not a question of total solubility, the issue is the domain of validity of P=H x (Henri) In this case, it will hold for low concentrations only. I'd say that, up to 1% molefrac in the water the KVL coefficient would not change too much, at room temperature
For the design of the scrubber, select a good wetting rate (20 m3/m2/hr , estimate the NTU from the packing data and the physical properties, and you should be OK)
I found at least a reference using Henry's law for acetobe/water. I do not know how good this data is
Revue Journal of Atmospheric Chemistry
Éditeur Springer Netherlands
ISSN 0167-7764 (Print) 1573-0662 (Online)
Numéro Volume 20, Number 1 / janvier 1995
DOI 10.1007/BF01099916
Pages 17-34
Subject Collection Earth and Environmental Science
Henry's law coefficients for aqueous solutions of acetone, acetaldehyde and acetonitrile, and equilibrium constants for the addition compounds of acetone and acetaldehyde with bisulfite
H. -J. Benkelberg1, S. Hamm1 and P. Warneck1
Abstract Vapor phase concentrations of acetone, acetaldehyde and acetonitrile over their aqueous solutions were measured to determine Henry's law partition coefficients for these compounds in the temperature range 5–40 °C. The results are for acetone: ln(H 1/atm)=–(5286±100)T+(18.4±0.3
