jskernahan
All,
I need some help with a CSA Z662 interpretation. Here's the situation:
- I have a CSA piping spec that calls for the use of A105 valves in a LVP (oil), low temp (-45 deg C), PN100 (9930 kPag) service.
- CSA Z662 table 5.1 states that LVP service is categorized at Cat. 1 with no min temp limitation, meaning materials do not need impact testing. Table 5.3 further states that B16.34 valves, any grade, can be used in Cat. 1 without limitation. This is the spec owner's justification behind using A105 material.
I've always said that A105 material is only acceptable at low temps if it has been impact testing (at the low temp), due to the materials tendency to become brittle. Has anyone justified using A105 at -45 deg C without impact testing? And if so what was the reasoning? Thanks,
