engineeringguy;
This is one of these questions that has so many variables I am not sure what type of of evaluation one could make with reasonable accuracy.
The first issue is quality of weld metal. Welds are cast structures that contain inherent flaws.
Second, is the level of residual stress which is a function of preheat, weld deposition sequence, etc.
Here is how I would approach this problem - assuming two welds with similar inherent flaws and similar residual stress levels (same base material, same dilution effects, same preheat, same deposition sequence;
the 7018 deposited weld will exhibit higher tensile and yield stregnth in comparison to 6010, this is based on 70 Ksi minimum UTS for 70xx versus 60 Ksi minimum UTS for 60xx weld rod. Since for wrought steel, the high cycle fatigue strength is approximately equal to 50% of the ultimate tensile strength, one could assume that the weld deposited with 7018 as the bulk (6010 root + 7018 fill), will generally have higher fatigue strength in comparison to the all weld deposit of 6010. This is about as far as I could go with this because any further conclusions would be pure speculation.
