I need help wiring an electrical test station. This test station is used to test an commercial wet/dry vacuum system, in an industrial, production enviorement.
here's what i have;
i have 208 volts comming into my test box from a gfi breaker in the wall, (2 hots, a neutral, and a ground) a Staco, model #2520, Series Variable Transformer. I need this variable voltage control because we manufacture both 110vac and 220vac models. The problem lies here, because we test in a wet enviorment, i need to inexpensively GFI protect the operator. The Staco schematic only shows a the use of the 2 hots, where does the neutral go? Staco tech sup. says leave the neutral hanging, and the operator will still be protected, is this true? i have also seen these little pigtails with a gfi on them, but not in a 240 volt model will this work?....any sources on them? any help will be appreciated. thanks.
here's what i have;
