Beam Reinforcement Calculation 5
Nick6781
CA
Let's say I need to use a web plate instead of a flange cover plate (I know...) to reinforce a beam. How do I calculate the required weld to ensure the section acts compositely? The shear flow equation gives the shear along a horizontal plane, but in this case, the faying surface is vertical. I can't quite wrap my head around it.
@BAretired is correct the definition of Q in VQ/I formula is the first moment of area above or below the shear plane being considered
This is how I've always understood it as well. You're only using the area past where you are trying to find the q value for.
Giving it more thought VQ/I at the top and bottom of the reinforcement plates is 0, still would be curious to see the model with intermittent fasteners at the top and bottom of the plates rather than at the centroid.
Exactly. I have modelled it and it doesn't matter where the fasteners are located they are only transferring vertical shear. This is exactly as one would expect because there is no compound action. And no longitudinal shear demand on the fasteners. (To be pedantic if the fasteners are intermittent then you do have some extremely small longitudinal shear demand.)
Of course there is longitudinal shear flow in the plate and in the web of the beam but they are equal so there is no shear demand on longitudinal fasteners. (No shear flow between the plate and the web as I expressed earlier.)
If you have the time I would really suggest reading THIS thread.
@CANPRO argues the same point tirelessly. Against quite a few disputing including BARetired.
This post from KootK is another decent summary.
VQ/I is zero at the top of the cross section, but not at the top and bottom of the plates.
Perhaps a calculated example (not software) would clarify the difference between though processses here.
I agree with this 100% this approach to the calculation IF we were trying to calculate the shear requirements of fixing that top T to the rest of the assembly. And my next step check whether that web is strong enough to transfer the shear which it is. Hence no welds required to transfer
It has been calculated. And that calculation has been denied. It has been explained in a dozen different ways using logic and that has been ignored. I've tried pointing to the other thread.
What matters here is that if in the absence of a connection there would be a discontinuity in the stress gradients. This discontinuity needs to be resolved if there was going to composite behaviour.
But in the case of members that have a common centroid there is no discontinuity in the stress gradients if they are simple 'sistered' together. stress and strain are identical. Thus there is no discontinuity.
YET ANOTHER EXAMPLE:
Consider a Square hollow section cut down its axis and calculate the shear and the weld required. Using VQ/I in the major axis we wouldn't required any weld as the resistance to bending is unchanged. The calculation unsurprisingly yields a ZERO result. Though calculate it for the minor axis and you have a completely difference result, again as expected. You'll find yourself needing to weld that cut back up to restore the strength stiffness in the minor direction.
If the beam is being loaded by UDL applied to the top flange, doesn't the weld from top and bottom of the reinforcing plates need to be sized for Q, similar to how you'd do it if you were reinforcing with a T as BA drew? Otherwise how does the side plate go along for the ride if it's not designed for the stress to act compositely?
If the load were applied such that the plate and beam both got engaged, say with screws into the side (just as an example) then I'd get that they both get loaded, but otherwise how does any load make it into the plate without sizing for Q?
Good question.
The side plate goes along for the ride by providing sufficient fixings to transfer the vertical load. This could be screw, bolts, welds, or whatever regularly spaced. Those fixing would need to be designed for the proportion of the UDL load transferred which could be calculated by the ratio of plate stiffness to I beam stiffness. It would be very low and much lower than an incorrectly applied QV/I shear calculation. The load also acts in a direction perpendicular to the shear value that is calculated by QV/I.
People keep talking about this member acting compositely. When it really isn't. It is acting in tandem, as though it three sistered sections, not compositely. If you doubt this just calculate the I value for the 'composite' member and the I value for the sistered member. They are identical. You are not getting composite action.
When designing for connections for a composite beam you need to allow for shear in two direction. Longitudinal and in the direction of the load (down for a normally loaded beam). QV/I is only half the story. In this case it equals zero, but the other half doesn't which I've pointed out repeatedly.
Horizontal shear in the web and side plates must be resisted by welds top and bottom of side plates. The value of Q is shown below in two places, at the top of plates and at the neutral axis. Horizontal shear stress is VQ/It where t is the material thickness at the position under consideration. At the neutral axis, it would be the web plus side plates. That is true and cannot be dismissed by using faulty arguments.
In this case, little is gained because the side plates are only about half the depth of the beam. Much more effective would be to beef up one or both of the beam flanges, but this is the problem we were asked to address.
The horizontal shear at the top of the side plates is zero. The only area where shear can be anything but zero is at the corner of the side plate and existing web - but in any case this is the same amount of shear in the web as was there before the plating.
Just above the welds, the horizontal shear is in the beam web, not the side plates. Just below the welds, shear is shared by the side plates, although there could be a bit of shear lag, so the shear stress needs to build up. I agree that Q above the welds is unchanged by the presence of side plates, but it starts to increase to a maximum at the neutral axis. Depending on the thickness of side plates, shear stress may actually decrease at the neutral axis.
Wouldn’t the shear stress be concentrated and uneven with the proposed concept. Also isn’t welding that near to the flange web interface weaker the beam.
AISC recommended strengthening methods
I see where BA is coming from thanks to that visual. He is looking at it based on just half the beam. So the top weld is based on the top half of the beam and the bottom weld is based on the bottom half of the beam.
But here the plates are one piece with equal amounts above and below the centroid of the whole section.
So to simplify it seems like the main discussion point is checking top half and bottom half separate vs VQ/I for the whole built-up section. Is that right?
BAretired you really should be more professional in your discussion on this topic. I appreciate your engagement but I haven't appreciated your lack of respect or engagement on this topic.
Please do us all a favor and review your textbook on Strength of Materials.
The topic is nuanced. As I've repeatedly indicated. And when designing welds or fastenings you don't actually care about the shear flow in the area A, you care about the difference in shear flow between two areas. AKA the shear flow gradient. Or more accurate the stress/strain gradient induced by the shear flow...
If you calculate the shear flow in section A, B and C in the absence of a weld then you will find that you have identical longitudinal stresses/strains. (To do so you'll need to allocation V suitably and use different I values for A,C and B.
Thus you can throw all the weld there you want or none of the weld there and the result will be the same. There is no force flow across the boundaries between A, B and C. (If we include shear lag AND if the beam is top loaded then you can get some small difference if we want to be pedantic.)
Guilty as charged...I apologize for my unprofessional remarks.
Apology accepted. We are all human, and get frustrated when others don't seem to listen to what we think are well expressed arguments. I count myself here, and no doubt you have been somewhat frustrated.
BA - I think there may be some confusion about the Q term here. The way I see it the areas you show in the photo for the Q term would be correct if the assembly was made up of (2) WT sections (in black) welded to a very thick plate (thickness of web + 2 side plates) - shown in blue in your diagram. However, that is not the case here. We have a continuous W beam with only the side plates being attached. In this case I think the area for the Q term would be the area of the side plate (Asp), and the Ybar term would be distance from the neutral axis of that area to the neutral axis of the composite section - or 0. therefore Q =Asp*0 = 0. Numerically this would result in a shear flow of 0 at the interface between side plate and W beam (This is all assuming that the side plate is centered on the web)
In more practical terms - there is only horizontal shear flow where loading would induce horizontal "slip" between surfaces (like in the case of flange cover plates or a million other examples where the neutral axis of the area of the connected part does not correspond with overall section neutral axis).
I still maintain that there is no real shear flow here and the reinforcement would only need to be connected adequately to share its portion of load (in proportion to stiffness), adequately to brace the plate against buckling concerns, and potentially adequately to get the plate's share of load back "out" of the plate at the bearing or connected end of the beam.
Thanks RWW0002,
You are probably correct. I am still struggling with it, but I have spent far too much time on it already. I may take another look at it when the fog clears from my brain.
I tried to solve Problem 543. in "Elements of Strength of Materials" by Timoshenko and McCullough, which I thought was somewhat similar to the problem we are discussing, but I keep coming up with the wrong answer. (should be 227 psi).
Problem 543. It's the yellow area. Maybe someone can get it right.
I second you for this debate.
Max shear stress will be at bottom of 2X4 piece.
Max. Shear force V=5000 lb.
MOI of the section=(2*12^3 )/12+ (12*4^3)/12=352 in4
First area moment of 2X4 piece Q=2*4*4=32 in3
Max shear stress τ=(5000*32)/(352*2)=227 psi
