Truss Top Chord Lateral Support 1
hoshang
IQ
Hi all,
For a Pratt truss, lateral support is provided by a transverse U-frame consisting of the floor beam and truss verticals. What about a Warren truss? It doesn't have verticals.
BAretired said:
The cross braced members would be considered tension only as they appear slender enough to buckle under a compression load.
Can cross brace members be ignored in gravity load analysis if they were to be considered as tension only? If so, the support structure in the foreground would seem like the attached image, isn't it?
X-brace members have zero stress under gravity load, but they cannot be ignored because they are required for stability of the structure (actually only one member is required for stability, but it would have to be capable of resisting both tension and compression).
Under wind load from the left, the solid red member would be in tension. The dashed red member would be in tension for wind from the right.
BA,
appreciate your valuable insights. Please find the attached image:
Assume the cables and its supports don't exist, the truss is supported by the inclined member (blue) via bottom chord (green). Why is the horizontal member (red) is there? Can't floor beams (yellow) between the blue lines take the same role as the red one (i.e., make yellow and red as one member? Why the red line is lower than the yellow one? is it to make a room for welding? The inclined member (blue) isn't in the plane of the truss, how the joint connecting green, blue, truss diagonal can be analyzed and designed?
BA,
The red member supports the green chord which does not align with the top of the blue member. The black member is decorative, not structural, and it prevents alignment of green chord and blue support. But even if they did align, I would use the red member to tie the frame together, making transport and erection much easier.
The yellow beam (and others) are part of the floor framing of the bridge. It is not easy to see precisely what is going on there, but it is quite possible that the floor structure contains a horizontal truss to carry wind forces (just a guess). The yellow beam cannot "take the same role as the red one" because they are not aligned.
The blue member is certainly not in the plane of the truss...it's not even parallel. The green bottom chord rests on the red member very close to the top of the blue member.
The top of the inclined blue member fits into the bottom of the decorative black member. Its design is quite simple...design it as a simple compression member, pinned both ends with compressive force P = slope component of the vertical bridge reaction plus the slope component of the wind reaction.
But there doesn't seem any attachment between the green and red lines. They're at different elevations.
I drew the yellow member at a noticeable location. There exist a yellow member (floor beam) over the red member too, isn't it? If so, can't they be combined into one member? Please see attached image for my point.
You could do that if you wish. The bridge in the photo couldn't do that because of the bent pole projecting up where you show the railing. Personally, I like the red member because it makes the support easier to erect, although it still has to be supported to prevent it from falling over. I visualize a prefabricated bridge brought to the site, then just bolted in place to the rigid supports.
By the way, 5'-0" truss depth will not be enough for a 90' span. I thought you indicated a depth of 7'-6". Even that may be a bit tight for headroom. I visualize a horizontal truss in roof and floor of the 90' span to resist wind pressure (sort of a box like structure). The handrail would be inside the truss.
BA,
Excuse me not figuring it (E is my second language).
Can you elaborate more on this?
No need, it was not clearly written and is not really important. In structures, there is usually more than one way to do the job. I cannot tell from the photograph precisely how the members came together. Do it your way. Then you can say, like Frank Sinatra, "I did it my way".
So, the load path for gravity would be: decking-stringer-floor beam. These gravity loads together with the truss self-weight would be transferred to the bottom chord and then directly to the inclined member. Isn't it?
I wounder if there are constructability issues of this setup.
This is for the foreground support structure. Regarding the background support structure:
There are two frames in the background support structure: one with cross bracing, and the other with V-bracing. Is it aesthetically or structurally required? How would the gravity load be transferred from the bottom chord to the support structure? Is it transferred directly from the bottom chord to the support structure? If so, there would be two points for each bottom chord to transfer the gravity loads to the support structure: one on the frame with cross bracing, and the other with V-bracing. Isn't it?
Red member helps to reduce the stress on the connection between green and black members. I don't know the details of that connection and if it is really required or not, but this is what is happening there.
Sounds about right.
There may be constructability issues.
a) You probably won't have tapered sloping poles like these, do you?
b) Black, cranked tapered, decorative poles (non structural).
c) Looks like the blue supports fit into the black cranked tapered poles?
d) I will not comment on these members, The end supports must resist vertical load, wind load and possibly seismic load.
e) I don't know what this is. Looks like a wall.
Hi BA,
Can floor beams be placed higher than bottom chord elevation (i.e., 500mm above bottom chord)? If so, assuming vertical members of the truss are HSS (square or rectangular) and floor beams are wide flanges, how would the connection be between them? Is it a shear tab connection? I'm curious how the truss is supported on the two frames (cross braced and V-braced frames) at the end. Is it considered as one-point support or two-point support (on cross braced and V-braced frames)? Since during the analysis, it's considered as a truss supported on one point at the end rather than two points. How a one-point support can simulate a two-point support?
Hi BA,
Yes, I believe so. Connection should be a moment connection to laterally support the top chord.
Hell no! That would be a pin joint. You need to prevent rotation of the verticals.
I think you need to develop your basic concept first before going into these details.
If I recall correctly, you indicated that you will have two 90' spans, so you will need three supports, four if each span is simple. Each support must resist gravity and lateral load. Probably the central ones will resist force parallel to the bridge axis. You may have a different configuration of supports than the one in the photo.
In post #4 my thought was to add top struts to laterally support the top chord. So, this is how my query came out:
Can you explain how you would simulate this support in your model if it were you:
Can this end support withstand longitudinal forces (from thermal loads)?
There doesn't exist stair at the end support, could it be? If there would be a stair at the end, how would the stringers (Channel sections) be connected to the bottom chord (HSS section)?
Cross braced frame and V-braced frame have one foundation. Do you have any idea why they made such cross-braced frame and V-braced frame at the end support?
You could avoid thermal forces by designing the middle support for longitudinal forces and allowing each end to slide horizontally, in other words, an expansion joint..
If there is no stair at the end supports, there must be a ramp. Otherwise it is one big step.
I won't comment on the other design as it may not be suitable for your project.
There are many ways to frame the bridge. I like the concept in the elevation below. The orange tee shape would be erected first, then the two blue trusses would be connected at both ends. In effect, each blue truss is free to move outward horizontally with two pins on exterior support.
