Truss Top Chord Lateral Support 1
hoshang
IQ
Hi all,
For a Pratt truss, lateral support is provided by a transverse U-frame consisting of the floor beam and truss verticals. What about a Warren truss? It doesn't have verticals.
BAretired said:
The cross braced members would be considered tension only as they appear slender enough to buckle under a compression load.
Can cross brace members be ignored in gravity load analysis if they were to be considered as tension only? If so, the support structure in the foreground would seem like the attached image, isn't it?
X-brace members have zero stress under gravity load, but they cannot be ignored because they are required for stability of the structure (actually only one member is required for stability, but it would have to be capable of resisting both tension and compression).
Under wind load from the left, the solid red member would be in tension. The dashed red member would be in tension for wind from the right.
BA,
appreciate your valuable insights. Please find the attached image:
Assume the cables and its supports don't exist, the truss is supported by the inclined member (blue) via bottom chord (green). Why is the horizontal member (red) is there? Can't floor beams (yellow) between the blue lines take the same role as the red one (i.e., make yellow and red as one member? Why the red line is lower than the yellow one? is it to make a room for welding? The inclined member (blue) isn't in the plane of the truss, how the joint connecting green, blue, truss diagonal can be analyzed and designed?
BA,
The red member supports the green chord which does not align with the top of the blue member. The black member is decorative, not structural, and it prevents alignment of green chord and blue support. But even if they did align, I would use the red member to tie the frame together, making transport and erection much easier.
The yellow beam (and others) are part of the floor framing of the bridge. It is not easy to see precisely what is going on there, but it is quite possible that the floor structure contains a horizontal truss to carry wind forces (just a guess). The yellow beam cannot "take the same role as the red one" because they are not aligned.
The blue member is certainly not in the plane of the truss...it's not even parallel. The green bottom chord rests on the red member very close to the top of the blue member.
The top of the inclined blue member fits into the bottom of the decorative black member. Its design is quite simple...design it as a simple compression member, pinned both ends with compressive force P = slope component of the vertical bridge reaction plus the slope component of the wind reaction.
But there doesn't seem any attachment between the green and red lines. They're at different elevations.
I drew the yellow member at a noticeable location. There exist a yellow member (floor beam) over the red member too, isn't it? If so, can't they be combined into one member? Please see attached image for my point.
You could do that if you wish. The bridge in the photo couldn't do that because of the bent pole projecting up where you show the railing. Personally, I like the red member because it makes the support easier to erect, although it still has to be supported to prevent it from falling over. I visualize a prefabricated bridge brought to the site, then just bolted in place to the rigid supports.
By the way, 5'-0" truss depth will not be enough for a 90' span. I thought you indicated a depth of 7'-6". Even that may be a bit tight for headroom. I visualize a horizontal truss in roof and floor of the 90' span to resist wind pressure (sort of a box like structure). The handrail would be inside the truss.
BA,
Excuse me not figuring it (E is my second language).
Can you elaborate more on this?
No need, it is not important. Do it your way.
