Is a Masters needed to be a Sturctural Engineer
Do you think it is worth it spend 2 years to get a Masters after graduating to become a Structural Engineer?
*Eng-Tips's functionality depends on members receiving e-mail. By joining you are opting in to receive e-mail. Posting Guidelines |
Is a Masters needed to be a Sturctural EngineerIs a Masters needed to be a Sturctural Engineer(OP)
Recommended for youRed Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! Already a Member? Login |
News |
RE: Is a Masters needed to be a Sturctural Engineer
Otherwise, come back to it part-time after a few years working experience.
Recommend working a bit first, then get a masters if desired. That way you can focus your courses on your interests and needs. Plus larger companies often pay the tuition if you go part time.
If you don’t plan to go into academia or a heavy r3search area, look for a masters program 5hat does not require a thesis.
Also, if you could get a job at a really good design firm with a great mentor who is able to dedicate some of their time to your development, I think that would probably be a better use of the 2 years than at school. This would have the added benefit of not increasing your financial debt. Of course, it's somewhat unrealistic to end up in this type of work environment with a great mentor who isn't also so busy that they actually have time to help you.
Overall, if your goal is to become better at the profession, whether you get a masters or not, you should expect to spend a lot of time self-studying. Get good at figuring stuff out on your own, and ask knowledgeable people questions when you're stuck. Study design guides and example problems. Go to this site and others like it where you get to discuss and learn about real world problems, not the friendly, sugar-coated problems you tend to get in a classroom setting.
Get your masters
Or you can be a good salesman and not even pass the PE exam and get promoted above all the engineers in your company. Entertain clients, etc.
Take (and pass) the FE exam before starting a masters program. In many USA states obtaining a masters degree in engineering will count as one year of experience toward a PE license.
But look into the requirements for immigration to US and for getting a PE license in a US state. Don’t know if you can take the FE exam in Canada.
I could try course based but it’s a risk because I might not get into that program. People that have done a masters, has it actually benefitted you at work? Did you get jobs/projects that you might have no gotten otherwise?
I agree with others that if you have a fully funded M.Sc. then go for it. Rarely is a course based M.Eng funded and it is certainly better if taken a few years out of school.
On the "complex projects", don't worry about that so much. My observation is that everyone wants to do the cooler projects, but there's more people wanting to do it than there are openings. So in ME, everyone wants to design the latest racing engine but somebody's got to design the door handles, too.
After my Masters, light bulbs went off all over my head. I truly understood what I was doing compared to before the Masters. So yes - it helped me enormously.
By the time I was about 10 years into my career I was in a position to hire younger engineers and after a while ONLY looked at MS degreed structural engineering students.
I hired some that only had the BS degree, and did OK, but could tell the difference for sure - there were exceptions but for structural - the MS degree is pretty important.
I had incorrectly assumed you were in the US and would have borderline crippling debt at the end of the two years.
One semi regret I do have is I never actually got my degree. I took all the course work but left to work before my thesis was finished. Once I was working finding time to complete that wasn't in the cards for me.
Once you're at a level to obtain licensure, it can become a mute point... unless you're trying to land at one of those few companies that only designs landmark structures.
Although, I would say that licensure isn't the end all. I've met plenty of PE's who left me wondering how they ever became licensed in the first place.
During the fall term (my fifth term), even the computer geeks could not help me as they were all having problems with their own programs. So I decided to leave without completing my degree. None the less, the advanced structural classes gave me an advantage over my peers throughout my career. I only knew of two other engineers with MS degrees as contemporaries. Some of my supervisors did have advanced degrees.
Thirty plus years later I completed a MS degree through the University of Idaho Engineering Outreach Program.
gjc
That being said, if you could BOTH work on your master's degree AND work part time at a structural engineering firm, you will get the best of both worlds. It will be more of a challenge. But, you'll get more out of both your degree and your first work experience.
I've known people who got their BS and only had a class in analysis and one that covered steel and concrete. That's not much of a foundation to build on.
I've also known people who had most of the critical structural engineering classes (analysis class beyond the basics, steel, concrete, wood) during their BS program. They would be OK without going to grad school.
Colleges are shrinking the number of credit hours required for a BS. Also, they're requiring more non-technical classes. From that, it seems like the importance of an MS is probably increasing.
Mike McCann, PE, SE (WA)
My current firm had a goal of hiring masters engineers, so it checked a box when I applied. But things have loosened up and we can't afford to be picky anymore. I'd rather hire a curious engineer with no drama than a basket case with a masters.
However, a few years back, there was a push to require a master's for licensure. I think it was beaten down, because I haven't heard about it recently. But it might just be sleeping and it could come back.
In your situation, getting it paid for, seems tempting, especially if you like an academic type of environment.
Around here in Kangaroo land a Masters degree on top of your Bachelor degree in a vocational profession, particularly immediately after, often sends a negative message. It suggests you lacked employment marketable skills so you went back to study to try to get ahead.
Also in general in most vocational professions further full time beyond bachelor study does not compensate for the opportunity cost of the time spent. Exceptions might be an MBA in some industries, but even these are being devalued.
Yeah it does sound like a great deal, though as above I doubt it is if you are prioritising a quick and lucrative career path. But that isn't everything.
If you are enthusiastic about continuing a student life of freedom, fun and semi-poverty then go right ahead. Plenty of wage slaves spend the rest of their lives reminiscing about the fun times they had as students!
{BTW, for background on my comments. I got my Masters as I returned to study as a mature age student and it was the quickest path to engineering with my BSc undergrad. I found it 80% a waste of time, I already had the skills but I needed the recognised Engineering qualification. Having the Master has never got me anything that a graduate degree wouldn't have done. All my success has been from hard work AFTER completing my degree.}
I know a lot of people will say this wasn't the way to go. But I found going back later made the masters easier and more helpful than if I had gone straight through. For starters I knew what questions to ask, and I knew which things were unlikely to be used. So I didn't stress out about certain things. But I think what really helped was that I knew how to draft, I knew how things went together, I knew about having a proper load path, etc... So again I think I was able to ask practical questions to my professors on how to apply what they were teaching into the real world of design.
So I don't regret going back later one bit. I was also more mature. I really recommend it for engineers that feel like their are things they would like to learn more comprehensively.
John Southard, M.S., P.E.
https://www.pdhlibrary.com/
If you want to become an actual practicing engineer, experience in the work is probably the most valuable. But a masters probably helps you fight the analysis paralysis of the common problem better.
I took the PE in Mechanical and then went back and took it in Structural and I do mostly residential work.
If i were in your shoes, I would def. get the MS.
I was going to flame you for these totally contradictory comments. PhD research is almost completely unrelated to real world engineering. A master's degree is absolutely necessary if you want to continue on towards a PhD, certainly. But, a PhD has VERY little to do with 98% of the structural engineering work done in the country. That work can be done quite easily without it. It can be done without a master's degree as well.
Then I read the last half of your post:
Tall buildings, building isolation, vibrations, structural dynamics. Yes, a master's degree will help with that. So, will a PhD. I sometimes regret not getting a master's degree when I was young. But, mostly just because I'd like to have the MS after my name, not because I think I would know more now than I would if I had gotten it 25 years ago.
That being said, I have worked extensively with structural dynamics and vibrations. Worked on lots of earthquake design. And, feel like I have an excellent understanding of all of that. Heck, I used to teach classes on the subjects to other engineers.
I've taken plenty of Master's degree level classes (or seminars) along the way..... when there was a subject I wanted to know more about. I find those classes meant a lot more when they were taken with a real world grasp of the engineering involved in the projects and how it will be used.
But, the reality is if you don't get your MS now, you'll probably end up like me.... satisfied with your career and knowledge, but with only a BS and SE after your name.
1) I had my PE/P.Eng prior to completing my MSc so it didn't make a tangible difference to my employment prospects.
2) I'm a staunch autodidact so I've relished rounding out my education via learning outside of a classroom setting.
3) I did my undergraduate work in Canada where there aren't very many terrible programs that one might pass through and, as a result, be woefully deficient in the fundamentals.
Frankly, I think that I -- and many people -- would be better off with an MBA.
There are some firms that prefer candidates with masters degrees, particularly for new grads. And a disproportionate number of those firms will be the ones doing the big, sexy projects that interest you. So that may prove a limitation. At the same time, it is my perception that those firms also tend to be the ones where business training carries the most weight. Mega projects desperately need capable project managers to ensure that they don't become mega fee gobblers.
Plenty of MSc's and PhD's wind up spending their careers trying to prove their worth to their B.Eng/MBA overlords.
But, yeah, if you're bound and determined to be a dedicated computational modeler of wind damping systems at Thornton Tomasetti, Magnusson Klemencic, etc, back to school you go.
The most difficult class I took was an advanced math class that I was forced to take that had absolutely nothing to do with structural engineering. None of the other five courses accepted for that requirement were actually taught that year, which was certainly a surprise to me. Also the professor that taught masonry took a sabbatical (no replacement) and the concrete professor broke his wrist (concrete courses cancelled for a semester). Plastic analysis of steel went from taught every winter to taught every other winter in the year I would have taken it. The most practical class I took was a wood design course taken through the architecture school. It was a struggle to even find available courses.
Like I said the degree did help me get my first job, but that was more for the piece of paper than the actual education.
