moog3
Marine/Ocean
- Nov 29, 2022
- 68
We all know that if you want to change the body colour in a component, you need to go into the part, not do it from the assembly..
We have a grip file that CAN DO this from the assembly, so it must somehow be able to bypass this annoyance.
My question is.... is there a way that this can be done with .vb code (from the assembly) or should I keep doing it with grip code?
