Contact US
[MSC] Overmolding material compatibility
My thesis relies on desinging overmolding solutions of two components instead of carrying out an assembly step, thus removing the necessity to rely on a third party.
The substrate thermoplastic is the Ultramid® B3EG6, a glass fibre reinforced injection moulding grade polyamide. The overmolded material the Lupolen GX 5038, an HDPE.
How can I effectively research and verify if these two materials are compatible to be overmolded, considering additives will have to be added to promote better adhesion?
Substrate material datasheet: https://www.campusplastics.com/campus/pt/datasheet...
Overmolded material datasheet: https://www.lyondellbasell.com/en/polymers/p/Lupol...
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
